Front brakes dragging
Discussion in '6th Generation 2002-2013' started by Big_Panda, May 22, 2016.
  1. Big_Panda
    Big_Panda New Member
    Simi Valley
    Just got back from a trip from LA to AZ and back. I noticed that my front brakes are dragging. After getting home I turned the bike off and rolled it forward in neutral and the brake shoes are absolutely making constant light contact with the rotor 100% of the time. Is this an adjustment issue? Alignment? Is it easily fixable? It sounds like both the front right and left are dragging.
  2. NormK
    NormK New Member
    Probably the return hole is starting to block in the master cylinder, needs to be flushed out and the hole cleaned
  3. Terry Smith
    The other likely culprits for dragging brakes are corrosion on the sliding pins (fixed by removing the calipers, cleaning off corrosion and regreasing the sliding pins) or a buildup of dirt on the pistons that is stopping them retracting easily. Remove one caliper at a time, lightly pump the pistons out a little (not too far!) and clean back to shiny metal using a toothbrush or scotchbrite pad, rinse off with brake cleaner, then push the pistons back in. They should move smoothly with firm thumb pressure.
  4. duccmann
    Sounds easy enough. Better get er done by Thursday B
  5. Terry Smith
    Panda, I should add that pads dragging on discs is normal. Pads binding on the disc are not. With the front end elevated, with a hard spin you should get a couple of full rotations before the wheel comes to a stop.
  6. Big_Panda
    Simi Valley
    Ah! ok, then I may be experiencing normal operation. I wouldn't say they are binding but just ever so slightly touching. Ill try the free spin test though.
  7. Big_Panda
    Simi Valley
    Got it up on the center stand and had the wife sit on the back to get the front up. Sure enough it had a couple rotations on a spin. No problem!
