front end vibration under braking
Discussion in '6th Generation 2002-2013' started by jsalty, Aug 8, 2008.
  1. jsalty
    jsalty New Member
    Inverness, FL
    when i pull the front brake lever i get vibration in the front end.
    this is not with light braking but happens with moderate to heavy front lever usage. can use the rear peddle hard, moderate or light and no vibration.
    any thoughts i have 12k on the bike
    Most likely a warped rotor.......a dial gauge will be able to detect and measure the extent of the runout.
    If the rotors are within runout specs then you need to start checking front end component bolt torque, brake pad wear patterns, tire wear pattern, wheel bearing condition, caliper operation, steering head bearings, fork tube alignment. Give the front suspension and front brake components a thorough check.
  3. jsalty
    jsalty New Member
    Inverness, FL
    Thank you,
    I have just replaced the brake fluid and noticed it.
    under hard braking only.
  4. 34468 Randy
    Check front tire for cupping. A likely cause. Experienced the same with mine.
  5. Joey_Dude
    Joey_Dude Member
    North Georgia
    I had that problem before and replaced the front brake rotors. No more vibrating now.
