Front Fork has air valve???
Discussion in '1st & 2nd Generation 1983-1989' started by jerdub77, May 23, 2008.
  1. jerdub77
    jerdub77 New Member
    Houston, TX
    Okay,
    So, I just got my brand spanking new 1987 VFR700F2 home, and was looking at everything. I unscrewed a black cap off the top of one of the front fork tubes (not sure of the exact term) only to discover an air valve much like the valve stem on a tire. I had some air shocks on an old Suburban that I cold raise and lower by raising or lowering the air pressure.
    Is this the same deal? Enlighten me from my ignorance, please!
  2. mello dude
    Yup - its air pressure valve. I dont remenber the specs but it was something like 2-8 psi, not a whole lot. I would find a manual and check out the spec before you play with it.
    The forks are pretty old tech in the first place.
    MD
  3. koorbloh
    koorbloh New Member
    Lynnhood, WA
    I asked the same thing when I did my shocks...
    *if* you are going to run any pressure in them, just make sure you don't put too much in them or you could blow your fork seals
    use a bicycle pump, and go slow
    generally, no need for adding pressure, was the answer I got
  4. Lgn001
    Lgn001 Member
    Russian River by Ocean, CA
    It was Honda's way of making the forks more "progressive" in their travel resistance, much as a progressively wound spring does, or adjusting oil height in the fork tubes to vary the size of the air chamber volume. Same general idea, kind of the early days of adjustable suspension. Varying the air pressure will also adjust initial (or "static") sag to some degree.
    Anyway, they tend to be really low pressure, as mello dude already pointed out. It is worth buying a pencil-type low pressure air gauge, like 0 - 20 PSI, as the max pressure is probably less than 15 PSI. The CB1100F (1983) calls for an inflation range of 0 - 8 PSI, and 2 PSI seems to work the best. I always use a hand pump, and it takes very little motion to over-inflate them, like 1/2 a stroke.
    Sorry I don't know the pressure for your bike, but hopefully the above helps a bit.
  5. squirrelman
    the max pressure is 6 psi, but few riders put air in the forks........
    Progressive (brand) springs do help the forks if you decide that help is needed..
  6. fabinator
    fabinator New Member
    Seattle, WA
    Yeah, 6 is indeed the max for the front, but there is no minimum. I personally ride without any, since 25 year old fork seals provide a plenty stiff setup.
    The rear shock requires at least 7psi. I'm not sure what will happen if it's lower, but it probably won't be good. I believe the max is 43psi, bit not sure. I know for sure it's more than 40, but you'll never want it that high... your lower back will return the favor the day after using more than 15psi. I think the high end of the pressure range is strictly for use with perfectly flat surfaces... public roads are too bumpy.
