Front Master Cylinders touch windshield
Discussion in 'Mechanics Garage' started by mtthwmrks, Jan 12, 2009.
  1. mtthwmrks
    mtthwmrks New Member
    Have a 92 vfr 750...Painted the bike and notice when I put everything back on that the left Master Cylinder is about half Inch or maybe close to touching the bottom of the windsheild when turning?
    It could have been like that before but i didnt notice
    What can i do to correct it?????
    Loosen the bar clamp bolt and move bar back toward you.
    there's a locating pin that drops into a slot, and a small amount of adjustment is available there bcuz pin is smaller than slot....
    if necessary, you could file a SMALL amount of material off slot or pin.
  3. mtthwmrks
    so its not the windshield thats causing the problem its the handlebars?
  4. squirrelman
    i dunno,could be the bodywork not mounted just right...
