Front/Rear chicken strips.
Discussion in 'General VFR Discussions' started by Molsan, Jul 21, 2008.
  1. Molsan
    Molsan New Member
    Red Deer Alberta
    Noticed that the chicken strips on my rear tire are a lot smaller than those on my front tire... Is this normal?
  2. nvoges
    nvoges New Member
    Columbus, OH
    It's fairly common to for the rears to be somewhat smaller, ti depends a lot on the type of tire you use. I have Michilen Pilot Road 2CT's and my strips are about twice as wide on the front compared to the rear.
  3. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    Yep Molson...you are good to go.
    BZ
  4. Molsan
    Molsan New Member
    Red Deer Alberta
    thanks a lot... was a little worried.
  5. Jessiah1
    Jessiah1 New Member
    If your rear preload is set too low it could be squating on the rear tire. Bike will fight to turn into the turn a little if the rear is squating and it will not hold a line well. You shouldnt be able to ride the edge of your front tire unless your on a track hauling A55, but certain suspension settings can keep you from using more front tire.
  6. drewl
    drewl Insider
    Virginia Beach, Va
    Mine are less in the front than in the back. Pilot Powers.
    Am I gonna die?
    I'm quitting the forum.
  7. powerslave
    powerslave New Member
    winnipeg,manitoba.
    My rear is worn right to the edge,even the footpegs are scraped down..and STILL have a narrow chicken strip on the front!!!!
    so...I think we are NOMRAL
  8. Molsan
    Molsan New Member
    Red Deer Alberta
    Have both tires been on the same amount of time?
    may need to check you suspension..
    http://en.wikipedia.org/wiki/Chicken_strip
  9. Shinigami
    Shinigami New Member
    USA-West
    Front is a PP, rear a PPCT2, 585 miles on the rear, 3300 on the front, rear has 1/4" (and peg feelers are both scraped) while front has at least 1/2".
    I weigh 200 lbs and have the rear maxed out and front maxed -1 click. I have no cupping and the previous PP wore quite evenly. 50-50 canyons and freeway.
    Should I have reason to believe there is a suspension issue here? I have a similar pattern on my CBR (except NO strip left on the rear at 2100 miles).
    I have always thought there would/should be a front strip when street riding...
  10. zx5go
    zx5go New Member
    Southwest Missouri
    New set of Avon Storms, f/r sag both set at 38mm, and my rear is worn edge to edge while my front has at least 3/4" strip on each side. I think it's normal.
  11. NorcalBoy
    it is normal
  12. Bubba Zanetti
    Delaware
    Thanks Norcal...
    I set my suspension a couple months ago and was wondering what the hell...is it wrong? Feels right!?
    BZ
