Front wheel change...supporting bike....
Discussion in 'Mechanics Garage' started by Boosh63, Jul 31, 2013.
  1. Boosh63
    Boosh63 Member
    Timmins, Ontario, Canada
    I removed my header a couple of weeks ago to have it sandblasted and painted but I haven't got it back yet. My new front tire arrived and I'd like to get the front wheel off. I don't have a garage so hanging the bike up by the triple tree is not an option nor do I have a front stand. The question is...will the oil pan support what ever force is required to balance the machine while it is on the centre stand..or do I have to wait until the header is ready and jack under it? I think I know the answer but just looking for a sanity check. Thanks in advance!
  2. mello dude
    Romania
    Like this?
  3. Boosh63
    Boosh63 Member
    Oh my...it looks so...naked!!! So the answer is yes then? :smile:
  4. squirrelman
    Spread the load on the pan widely and no problem.
  5. mello dude
    Romania
    Yes - I just made a mini wood frame out of 2 x 4s so there was room for the drain plug to stay out of the way.(It goes between the boards) -- Easy peasy.
    Here's the official VFR high tech newfangled jack stand frame. (Adventures while intoxicated.:biggrin:)
  6. Boosh63
    Boosh63 Member
    That's great! The "real" reason the header came off was to replace the oil pan with one that had all of the fairing bolt tabs intact...I was missing one. So...I thought to get the header restored. Long story short, it would have been a real sad story if I ruined the new oil pan!!
    Thanks again fellas!
  7. suse
    suse New Member
    Nampa, Idaho
    Can this be done with the Fairing on? I can't see how you could fit a jack in there. I have a motorcycle lift. I hate to pull the fairing unless I have to do it. It's a PITA.
  8. Boosh63
    Boosh63 Member
    I would not advise anyone jacking the machine up with the fairing on.
  9. suse
    suse New Member
    Nampa, Idaho
    That's what I thought. I could not see anyway to support the VFR with the side panels on. I wonder why they make it such a pain to pull the covers off? The part I dislike the most is trying to get all the tabs to slip into the connecting panels. I always feels like I'm going to break one of them.
  10. ftl900
    ftl900 New Member
    Las Vegas
    When a bike is on the centerstand and I need the front wheel off the ground, I'll put whatever fits underneath, but I always use a 2x4 under the oil pan, so any sharp spots can bite into the softer wood, rather than getting broken off.
    Now I have a front and rear stand, but it wasn't always that way. Like many before me, I've had front and back tire off while the bike is jacked and balanced.
