Front wheel install axle flush on left forkleg
Discussion in '8th Generation 2014-Present' started by Viefare, Dec 26, 2020.
  1. Viefare
    Viefare New Member
    Sweden
    8th Gen
    Hi, so i have a question about axle alignment on left forklegs outside.
    According to manual it says to make sure the axle is flush on left forklegs outside, sp before tighten that pinchbolt on forkleg i pushed the forkleg inwards to be flush.
    But i realized something, i can push the forkleg a little bit more inwards so the axle sticks out of forkleg about 3-4mm....
    So i thought, if axle is flush outside forkleg then there must be a play between the wheel , side collars and forklegs..
    Any thoughts on this ?
    If anyone are to mount the frontwheel can you please check if you have the same phenomena as i do?
    Thanks and Happy New vfr Year
  2. fink
    fink Member
    Has been covered a few months ago. If you search back you will find it.
  3. Viefare
    Viefare New Member
    Sweden
  4. Terry Smith
    New Zealand
    The axle pulls up hard on the left spacer, bearing, bearing spacer, bearing, right spacer and finally the right leg, when you tighten the axle nut. The left leg is free to float side-to-side on the axle so that the fork tubes can be set parallel for least sliding friction, then the clamp holds it in that position.
    Grum likes this.
  5. Viefare
    Viefare New Member
    Sweden
    Thank you very much, that sums it up .
