Fuel issues
Discussion in 'Mechanics Garage' started by Grae1965, Aug 21, 2020.
  1. Grae1965
    Grae1965 New Member
    Hi,ive got an 86 vf500 and struggling with not getting fuel into carbs. It runs from petcock to t-piece fine,but from t-piece to carbs something is going wrong. Ive undone carb drains and nothing comes out,she starts ok if i put fuel directly into carbs via air filter(removed). Shes been standing a couple of years so am i correct to assume that its just a build up of crap? Please someone out in Vf land help,im so wanting to make her as good as i possibly can
  2. BoomerDave
    BoomerDave New Member
    Have you bench tested the fuel pump ?
    You can bypass it by running a line from the petcock directly to the carbs to verify the petcock functions.
    If fuel still won't flow, pull the petcock and inspect/rebuild it.
  3. BoomerDave
    I see I have replied to two separate threads by you on this topic.
  4. squirrelman
    you could try blowing compressed air through the lines. also, the small filters just above the float needle seats might be clogged.
  5. Dannoxyz
    Dannoxyz New Member
    S.F. Bay Area
    No fuel-pump on '86 VF500F, only '84-85 had pumps. Gravity-feed works fine on '86
    Float valves can also stick to their seats after sitting for while. If sat over 6-months, I suggest full carb rebuild:
    - split carbs, replace all fuel-rail O-rings, completely disassemble Z-pipe.
    - fully scrub all fuel-circuits with nylon scrub brushes and PEA- based fuel-system cleaner
    - poke out all bleed holes in jets, pilot, emulsion tube, carb venturi with matching size soft copper wire
    - soak all parts in ultrasonic cleaner for hours using non-polar solvent
    - micro soda blast all jets, fuel-circuits, bleed holes
    - replace pilot O-rjngs when re-assembling
    - replace float valves
    - replace float valve seats if face not OK
    - set float levels
    - replace float bowl seals
    I’ve owned 10 VF500Fs 84-86 models over years since my 1st brand-new 1986 model in 1987. Which I still own to this day. Along with 5 VFRs of various generation.
    I got sick of pulling carbs 4-5 times for ever deeper cleaning until it finally ran right. Now I just do full restoration job very 1st time around. Saves so much time and effort to get carbs back to factory-new clean condition. Bike runs like it just left showroom floor!
  6. bigbadbass
    bigbadbass New Member
    NEW YORK
    @Dannoxyz deja vu? VFR in my avatar look remotely familiar?
  7. Dannoxyz
    Dannoxyz New Member
    S.F. Bay Area
    Hi, is that you ducatiman? How'd you end up with my bike?
  8. bigbadbass
    NEW YORK
    Yup. Your bike? its MINE! :) When you geddit?
  9. Dannoxyz
    Dannoxyz New Member
    S.F. Bay Area
    I got it like 5-years ago and sold it last year after riding it 3x in prior year.
    I like specialised scalpel-focused bikes for each type of riding. Ninja 250s for commuting so I can slip through traffic and split easily. CBR600RR for canyon-carving rides. Both Ninja 250s and CBR for trackdays and racing.
    VFR was jack-of-all-trades that did everything well, but wasn’t best at anything. I always ended up selecting one of other bikes for each type of ride I did. Sad to see it just sitting around collecting dust, so I sent it on its way to someone else who will ride it more! :)
    At this point, if I end up doing 2-up touring, I will get ST1300!
  10. Diving Pete
    Also had a couple of ninja 250's - for getting through traffic they are awesome.. Over a 20 mile commute I was on average only 2 minutes quicker on my Blade than the 250..
    Also ridiculous MPG..
