Fuel mileage and volts
Discussion in '3rd & 4th Generation 1990-1997' started by bikeman, Jan 24, 2013.
  1. bikeman
    bikeman New Member
    NC
    Hi guys, 2 questions...
    1) Since the cooler weather moved in (30's for the low and 50's for the high) I have been getting diminishing fuel mileage, not bad. was 39mpg...is 35mpg. Will the cold air cause this or is it a carb problem.
    2) volts at idle (1100 rpm) are only 12ish, when cruising they are around 14v, is that normal?
    Thanks Joe
  2. MrSleep
    MrSleep New Member
    Verdigris, Oklahoma
    Sounds normal to me
  3. kennybobby
    kennybobby New Member
    1. cold engine
    2. normal
  4. white_335i
    white_335i New Member
    Houston
    Shouldn't cooler air lean the fuel mixture?
  5. rangemaster
    rangemaster New Member
    Albuquerque, New Mexico
    My '97 does the same thing. I ride year round, lately about 25F going into work about 50F coming home. I've blocked off the oil cooler and partially blocked off the radiator to get the temp up a bit-runs much better.
  6. Baddabing
    Baddabing New Member
    Idaho
    Winter blend gas has a lot to do with lower gas mileage also.
  7. ridervfr
    Belgium
    oxygenated gas for winter = crappy mileage.
