So, my fuel pump went out on me the other day. It was way different than when my chevy truck pump went out. When they go out, its not while your going down the road like my vfr. They like to go out when you need to get into your truck and go somewhere. They simply just won't work anymore. Anyways, so I debated putting one on from autozone, but I can't seem to figure out how much pressure or volume the stock one carries. I ended up getting a decent deal on one from ebay, but for future reference, since the spare ones are so few and far between and I am too tight to pay 190 bucks for a brand new one, does anybody know the specs? I also understand that they are built with a shut-off safety system for when the bike tips over and such. This would concern me with a aftermarket one, but if the price is right, it might be worth the risk. My bike isn't very pretty anymore, and it breaks down more than I ride it as of late anyways. Someone just :spankme: and tell me to quit crying already.
carburated is only like 5psi. aftermarket general purpose fuel safe pump for $30-60 will work wonderfully. I don't believe there is any tipover shutoff in that generation. The carbs would stop feeding fuel properly on their side, the engine dies, the crank stops spinning, the ignition pickup stops reading, and the fuel pump relay opens. someone will spank me if I got it wrong I'm sure. The fuel pump v. after market pump v. gravity feed debate has been hotly contested here many times.
my pump went out too and it was 158 for a new one for my bike. i went to napa auto parts and got a universal low pressure fuel pump 3-5 psi for 60 bucks and it works completely normal. i did have to buy the 2 90° brass fitting for like 6 bucks but it beats the retail for the official pump. i have an older model vfr but i bet that pump would work. here was my thread. http://vfrworld.com/forums/1st-2nd-generation-1983-1989/31956-87-vfr700-fuel-pump-help-please.html
You guys are the poo I knew somebody was crazy enough on here to try it. Thanks for the info. I was told not to go over 7, but I wanted to make sure.
