gadgets
Discussion in '3rd & 4th Generation 1990-1997' started by vfr3g, May 31, 2024.
  1. vfr3g
    vfr3g New Member
    Denmark
    Copenhagen, Denmark, Denmark
    Has anyone of honoured members installed a gear indicator on 1991 rc36?
    Well, i did some years ago an AcumenG8. Workef fine for many years and went bananas all of the sudden. All cables are fine, Tacho, speedo pulses are strong and fine. So is Neutral signal. It is a unit itself. Pity because i can not find it anywhere. Can anyone recommend another brand wit 3 cables? So called universal unit, but when you ask Google for that you get hundreds of them all for p&p to EFI bikes or some really primitive units with gear lever reed sensors. Total disaster since if you miss a gear it goes bananas and needs reset. More trouble than gain.
    Thanks in advance :)
  2. linkken
    linkken New Member
    Fortine, MT
    I don't get it!
    what's that for?
    Just in case you forgot what gear your in??
