Gas Tank Flush - 1995 question
Discussion in 'Mechanics Garage' started by the borg, Jul 4, 2022.
  1. the borg
    the borg New Member
    Hello all,
    I have just come into possession of a 1995 VFR750 that has sat for about 5 years. I have looked in the gas tank and there does not appear to be any rust just some murky old gas. My question is, should I just drain the tank and maybe flush it with some fresh gas or is there some other course of recommended action before I attempt to get it running?
    yes, drain and flush should be enough. get ahold of the honda service manual.
    good luck, how many miles on it ? photos ?
  3. vmotorman
    vmotorman New Member
    Olathe, KS
    And don’t forget about the fuel filter.
  4. the borg
    the borg New Member
    Do you have a recommendation for the fuel filter? Should I go OEM or is there a good aftermarket filter you recommend?
  5. vmotorman
    Olathe, KS
    OEM works for me.
    And don't forget about the carb rebuild.
