gas was poring out my exaust on 1995 vfr 750 F
Discussion in 'Introductions' started by Dominic81, Feb 23, 2012.
  1. Dominic81
    Dominic81 New Member
    My bike was shooting gas fumes out of the exhaust. So I figured my floats where stuck. So I cleaned them out. Now I keep fouling plugs. Any guesses
  2. rc24rc51
    rc24rc51 New Member
    Liberty SC
    sounds like a through carb clean is in order.
  3. squirrelman
    Could be sticking choke cable or something in choke system not closing properly.
    You're sure the plugs are the correct heat range for the bike or maybe you didn't fix the float needle problem ??
    If only one plug is fouled the problem is in that carb; if all plugs are dirty, problem is probably in choke cable.
    If your bike won't run nice without using choke, your pilot jets need cleaning.
    You need to be certain the battery is fully charged b4 troubleshooting.
