gel grips
Discussion in 'General VFR Discussions' started by jahlov420, Sep 12, 2009.
  1. jahlov420
    jahlov420 New Member
    Richmond, VA
    i have a 1987 vfr 700. does anyone have any experience on installing gel grips for this bike? i have the foam grips but they are starting to wear off. what tools do i need and which grips should i get?
    thanks, jimmy
  2. monk69
    monk69 New Member
    Danville,Va.
    If the ones you have aren't glued on you can either use air to blow them off, or cut them off....
    The best thing to put grips on with is rubbing alcohol. Soap can make it hard for them to stay put after installed.... it would be easier to remove the bar-ends.....
  3. mello dude
  4. jahlov420
    Richmond, VA
    rubbing alcohol....thanks for the tip....i guess the bar ends have some kind of screw that you unbolt. i'm new to riding the this is my 1st bike. i've put about a 1000 miles on it in 1 1/2 months.
  5. NorcalBoy
    Final Net aerosol hairspray, it's a lot cleaner and the grips set up in about 5 minutes, couple wraps of safety wire and you're done. It works very well when you have to get the new gel grip over a Symtec heat wrap, on the throttle tube, without distorting it. :biggrin:
  6. Snafu
    Snafu New Member
    Grip Tek...
  7. jahlov420
    Richmond, VA
    i used the hair spray method....worked perfectly. switched up the grips in 5 minutes
  8. volks6000
    volks6000 New Member
    Jacksonville , Florida
    use the PRO GRIPS, have a pair on now , works great
  9. Keager
    Keager Member
    pro grips here as well. Typically remove the bar ends, cut off the old ones, and I (don't flame me here) use brake cleaner as the lube to get it on. Got to do it fast. Melts the rubber enough to bond to the plastic below. Never had any issues with it moving.
  10. bluegen1e
    bluegen1e New Member
    NYC
