Gen 5 rr brake caliper swap
Discussion in 'Mechanics Garage' started by knighthawk, Oct 14, 2012.
  1. knighthawk
    knighthawk New Member
    Bordeaux,France
    Hey everyone!!!New kid on the block here looking for a bit of advice!!I have a Gen 5 special that I'm building,fireblade front end,SP 1 calipers etc etc,and I want to change the original 3 pot rr caliper for something a bit more conventional,like the rr caliper off a Gen 4 for example!Does anybody know if its a straight enough swap or will I need the Gen 4 caliper mount also!I greatly appreciate and advice or recommends!!!
  2. rmcdougal
    rmcdougal New Member
    Fortuna CA
    I hear if you use a 14mm master cylinder and bridge the third caliper piston, it works very well. No need to change it to anything else.
  3. mello dude
    Romania
    Knighthawk,---- I assume you are talking the rear caliper. It's much simpler to keep the stocker and bridge the 3 pistons together and like rmcdougal said, go with a 14mm master cylinder. RC51, F4i and several other Honda sport bikes are using 14s. Check my brake link below on a "how to" in detail. It works very well.
    Good luck
  4. vfrcapn
    vfrcapn Member
    Grass Valley, CA
    I used a double banjo bolt with a F4i master and hooked up both r brake lines to the original caliper. Seems to work just fine.
  5. knighthawk
    Bordeaux,France
    Thank you all very much for the tips and info,was going to change the rear caliper but reckon I'll give your ideas a go first and see how it goes!!Much appreciated!!
