Gen2 rear sprocket issues...
Discussion in 'Mechanics Garage' started by PyroMcnoob, Mar 16, 2010.
  1. PyroMcnoob
    PyroMcnoob New Member
    Riverside, CA
    I had my bike up on the jack to service my chain (needed a good scrub and lube) when I noticed a clicking as I turned the tire... It kept happening at the same spot as I rolled the tire, so I marked the sprocket with a marker... it would appear that somehow, my sprocket has gotten slightly warped or bent, and now one of the teeth isn't totally in-line with the chain... At first I thought it was just a bad link, but I inspected the chain and can see nothing wrong there... the tooth in question isn't actually damaged, has the normal wear on it, it's just angled in such a way as to cause this retarded click everytime the chain passes over it...
    So, my questions are these:
    -Is this an issue I should panic over?
    -Will it cause my chain to snap (seen this happen to a stranger on the freeway)?
    -Is there a cheap(er) aftermarket option for sprockets for such an elderly {I mean "classic"} bike?
    I'd appreciate any feedback you guys may have, right now it doesn't affect performance, it's just an aggravation...
  2. captb
    captb New Member
  3. crustyrider
    crustyrider New Member
    North Country, New York
  4. PyroMcnoob
    Riverside, CA
    thanks boys, I always forget ebay when I post from work=P
  5. PyroMcnoob
    Riverside, CA
    you guys really hooked me up with those ebaya ds, looks like I'll prolly be pickin up a new sprocket in the next 2 weeks or so... gonna have to pawn somethin' to afford it lmao
