Has anyone out there had any issues with the GiPRO skipping gears? I noticed when riding that when I shift to a higher gear that the GiPRO will actually skip the gear I was shifting to and then come back down to the actual gear I'm riding in. I was wondering if this happens to anyone else and if I need to reset the gear indicator again.
not quite sure i understand but if you mean, the gear is wrong while you are squeezing the clutch lever, then yeah that is normal. it will only read the correct gear when the clutch lever is released.
