go to first unread message
Discussion in 'Suggestion Box' started by Knight, Jun 12, 2016.
  1. Knight
    Knight New Member
    USA
    Can I set my profile to go to the first unread message in a forum, when I select that forum, by default?
    Otherwise I must view "newest first", which I am not crazy about, and I still have to locate the first unread message. It is only slightly easier to use.
  2. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    If you're logged in then you should be able to click on the double down carat and that will take you to the first unread post.
  3. Knight
    Knight New Member
    USA
    I want to know if this can be set as the default view.
