Gotta Turn a Wrench!
Discussion in 'General VFR Discussions' started by Raven, Sep 7, 2012.
  1. Raven
    Raven New Member
    Play Del Rey, CA
    I've only had her for about 30 days and I'm already itching to tweak her.
    She's essentially a stock 2003 VFR Interceptor 800 ABS.
    Everything seems to work just fine and I know what some of you are thinking... 'Just leave her alone, dude'.
    I never could leave well-enough alone, though.
    So, without going too far, too fast... what gets me the biggest bang for the buck? :cool:
  2. Scubalong
    NEP throttle lock best mod ever big bang for the bucks:wink:
  3. jethro911
    jethro911 Member
    Merrickville, Ontario Canada
    I found that tapered head bearings were the best bang for the buck. But a cruise control is also a pretty useful and cheap mod.
  4. Scubalong
    Gutted stock exhaust would be your second mod. Low cost little to none $$$$$ :biggrin:
  5. taylor65
    taylor65 New Member
    florence, al.
    As for cheap ones. Some good grips. I like the pro-grip gel style. Eliminates the numb tingling hands. For the more expensive ones a power commander and pipe seem to be very popular. Along with a freer breathing air filter and to disable the flapper and pair valve. Another good one and not to expensive are fork springs and shock springs set for your weight. And better than all that is the best gear you can afford.
  6. mello dude
    Romania
    -- As you roll down the road, what bugs you about the bike? ---- I've have my ride for quite a while, but when I first bought it, my quick list in 3 weeks of ownership went something like -- Steers like a truck, springs suck, fork damping sucks, shock sucks, linked brakes suck, flat spot at 10,500rpm. Week 4, the bike got stripped..
    What' s your list?
  7. stoops
    stoops New Member
    Milwaukee, WI
    Most bang for the buck? I'll go with gas in the tank and miles on the road. Wrenching is fun, but just throwing money just because? nah, just ride her, if a problem/annoyance comes up, fix that
  8. highway star
    highway star New Member
    North Mississippi
    My sentiments exactly. I would suggest mirror extenders, almost imperative.
  9. Raven
    Raven New Member
    Play Del Rey, CA
    Great to see so many replies. As I have little experience on sport bikes, other than about 500 miles on an '89 Yamaha FZR 400, I'm not too sure what 'good' would feel like.
    The VFR is kind of hard to steer in the canyons and at low speed, and it really fatigues my grip even after about 45 minutes.
    The transition from low rpm to higher where the secondary valves kick in is kind of spotty. And there's a bit of drift in the front end when dancing over bumps in the road.
    When wheeling around in the garage it's like pushing a sled. Not exactly a smooth rolling bike.
    I haven't felt a flat spot in the power band yet, so maybe I'm just lucky there. And the brakes seem spot-on.
    The exhaust note isn't pretty or commanding but I see some gut the canisters so that may be a solution for me, too.
  10. Raven
    Raven New Member
    Play Del Rey, CA
    I have to split lanes every day and the mirrors are pretty vulnerable already. How do you get the rear view without tagging someone else's mirrors? :confused:
  11. Raven
    Raven New Member
    Play Del Rey, CA
    Thanks... Will definitely look into that. I like longer runs and a cruise control is a great way to reduce fatigue.
  12. Raven
    Raven New Member
    Play Del Rey, CA
    Ok, so what function(s) do the flapper and pair valve perform, and how big a task is it to disable them?
  13. Raven
    Raven New Member
    Play Del Rey, CA
    Sorry for the naive question... What do tapered head bearings do for a bike? Make it easier to steer??
  14. mello dude
    Romania
    I'm kinda getting of where you are at on the bike, my suggestions are --- drop the front fork 5mm or there abouts - it will quicken steering some. - Unless you feel some looseness in the steering stem, you dont need to change the bearings yet. -- Grip fatique stuff-- First grap a set of Pro Grips, there are several kinds. My fav is the 699.
    Pro Grip 699 Open End Sportbike Gel Grip - Street Bike - Motorcycle Superstore
    Next add a throttle rocker- buy darn near any cycle shop or google
    Throttle Rockers : Amazon.com : Automotive
    Next practice going without a death grip on the bars. Do this exercise -- put bike on center stand and sit on the bike. Put your hands on your knees. Then lean just a bit forward, and then raise you hands off your knees and just touch the grips with 2 fingers each hand. See how your trunk is supporting your body? Now try to practice this on a ride with your hands "resting" on the grips. The throttle rocker will help you do this. It takes a while but once its a habit, your endurance will go up.
    Suggest to get more time on the bike and go from there.
  15. ridervfr
    What about your tyre condition and inflation? Just saying, would be amazed how many expensive bikes you see with under-inflated tyres are out there.
    As you get to know your new ride, feel free to experiment with suspension settings. You could slid the forks up in the tripple trees 5-10 mm which will quicken your steering. Could change your fork oil too, just the tip of the iceberg really, lots of wrenching to be done :smile: Cheers.
  16. Raven
    Raven New Member
    Play Del Rey, CA
    I appreciate the advice.
    Sounds like I have some homework to do.
    Aside from learning how to ride this bike whadoes I do to lower the front forks? Is there an adjustment wheel or nut or is it more involved than that?
  17. Raven
    Raven New Member
    Play Del Rey, CA
    You must have mind reading abilities. I've been meaning to check the tire pressure and every time I go to ride I'm looking at them thinking they look a tad low (but I get on her anyway).
    You're absolutely correct and I will make sure they're properly inflated before I turn the key this morning. And it sounds like you answered my question back to mello dude about lowering the front forks. I have a follow-up question, though... if I shorten the front forks by sliding them up, does that affect the shock response and if so, how?
    Many thanks!
  18. tinkerinWstuff
    The function of fucking with them is wasting your time. Honda put a flapper valve on the air box to make the bike bike cost more and prevent poor teenager from buyin their bikes. Or it's for still air in the box at idle and maximum low end torque. The PAIR simply takes fresh air and dumps it in the exhaust to burn off hydrocarbons. Simple design and has zero affect on horsepower. Some say disabling it has an affect on roll on throttle smoothness.
    Get the suspension tuned for your weight and riding style. You won't be happier. One size does not fit all. It will help your turning complaints in canyons.
  19. zoom-zoom
    zoom-zoom Member
    BC, Canada
    Soooooo, Mello, it must be asked.............How often do you spend at 10,500 RPM so that a flat spot bothers you?? Just askin???
    As for bang for the buck, my money might go with gel grips, cruise control (throttle locker), and suspension tweaking to suit your riding style and weight. After that maybe a Sergeant seat to extend your range and riding comfort.
  20. Badbilly
    Mthinks "Raven" should tone down the canyon carving down a bit or he may be another Mike Hailwood who didn't know all that much about bikes but could ride the shit out of one.
    MSF course? A day at Willow? A sleepover with norkleboy?
