Greetings/Gen 4 Mods
Discussion in '3rd & 4th Generation 1990-1997' started by KrabbyPaddy, Mar 8, 2021.
  1. KrabbyPaddy
    KrabbyPaddy New Member
    Cincinnati, OH
    Hello everyone!
    I've had my 1997 VFR 6 months now, and I've started modifying it little by little, and I have some questions.
    I'm wondering if anyone has used black widow header pipes, and if they're worth it.
    Are there any "must do" mods? I've tried looking around a bit, but I couldn't find conclusive answers.
    Anyways, cheers from Cincinnati!
    So, you've already upgraded all of the suspension then, right? ;-)
    Not worth the effort or money (for that particular system), imo. Likely will lose power thru most of the rev range. Enjoy the way your VFR sounds and runs with what looks like a decent high mount right exit slip-on.
  3. KrabbyPaddy
    Cincinnati, OH
    No I have not! (Part of the reason I'm here ;)
    Whats the best bang for the buck approach?
    Yes, thanks. With the slim pickings, it seems Delkevic was the only choice without being patent for a used system to show up somewhere.
    mello dude likes this.
  4. upwinger
    upwinger New Member
    Germany
    Behind The Redwood Curtain
    I have a decent carbon fiber slipon for sale. I'll try and find a pic if your interested
    Sent from my Pixel 3 using Tapatalk
    Suspension is always the best money spent on the performance of your VFR. Many alternatives on suspension. Suggest going to DMr Suspension and have a look around for starters.
  6. upwinger
    upwinger New Member
    Germany
    RaceTech is my first go to for suspension upgrades...but my vfr already had Ohlins put on front and rear.
    Another very good upgrade is a shift kit from FactoryPro. Smooth as butter. Just my 2 satoshis
  7. KrabbyPaddy
    Cincinnati, OH
    The FactoryPro shift linkage is an elegantly simple bit of kit. It's a shame its so expense for a standard bearing and a stamped bit of metal.. But I guess everyone needs to make a buck somehow.
    Wb a CBR929 rear shock? I've seen a couple posts elsewhere about it. If I did that, what would be an equivalent "cheap-o" front end improvement? Springs and oil?
    edit: It's not that I'm a cheap bastard, it's just that I'm a cheap bastard :D
  8. Brian Rodgers
    Brian Rodgers New Member
    Jarrell, Texas
    Some would say the alternator R/R upgrade is 'necessary' for increased reliability.
    KrabbyPaddy likes this.
  9. upwinger
    upwinger New Member
    Germany
    I know that the 929 rear shock was a very good upgrade for the 650 Hawk that had the ELF swingarm, but the upper hole on the shock had to be machined bigger and offset, so couldn't easily been done with a drill.
    Suspensions aren't cheap, but the RaceTech gold valves and springs/oil was a nice improvement on my 500 interceptor
  10. squirrelman
    not really necessary until your luck runs out and something fails. some do last ok.
