grips
Discussion in 'Mechanics Garage' started by troutkiller, Mar 29, 2013.
  1. troutkiller
    troutkiller New Member
    long beach, mississippi
    i have to upgrade my grips. my throttle hand gets so numb sometimes that i cant stand it! what do you guys recommend?
  2. mello dude
    Romania
  3. Maggot
    Maggot New Member
    Park Ridge, IL
    I bought gloves with gel in the palm . I think they are Tourmaster. They help a lot!
  4. cha6040
    cha6040 New Member
    DFW, Texas
  5. OOTV
    OOTV Member
    Unless the store is trying to rip you off, grips typically come in pairs.
  6. cha6040
    cha6040 New Member
    DFW, Texas
    That's what I figured, wanted to make sure
    Sent from my Nexus 5 using Tapatalk
  7. ridervfr
    I love the foam Pro-Grips for my interceptor. You have to cut off the bar end, but they make it easy...
  8. Badbilly
    Brilliant! What needs to be done is to find out all those stores that only send you one grip and tell them to get a grip. IMO
  9. OZ VFR
    OZ VFR Member
    Old Toongabbie, Australia
    If you're getting that numb, you're holding on too tight or resting on the bars too much.
    Also make sure your brake/clutch levers are adjusted to the right position for your height.
    I don't think new grips are going to make too much difference, but foam ones might help a bit.
  10. cha6040
    cha6040 New Member
    DFW, Texas
    I mainly want them because I have large hands and would prefer a slightly thicker grip, the cushioning is a bonus
  11. OZ VFR
    OZ VFR Member
    If big hands are your problem, foam grips are your best bet.
    They have a slightly larger diameter.
    PussyGrips make a foam sleeve that fits over your existing grips that fix this problem, not sure if they're available in the States.
  12. cha6040
    cha6040 New Member
    DFW, Texas
    Are the sleeves easy to install? I'd be interested in those for sure
  13. Allyance
    Allyance Member
    Germany
    East Bay, California
    Grab On makes foam grips to go over existing. http://www.grabongrips.com/
    I couldn't find any brick & mortar store that sold them, so I just got a normal set at Cycle Gear for $10, wasn't going to pay $7 to ship a $10 item. Don't glue on, something tacky like hair spray.
