gutted exhaust
Discussion in 'Mechanics Garage' started by junkins45, Apr 9, 2012.
  1. junkins45
    junkins45 New Member
    Keyser, WV
    so im confused. when doing the exhaust gut. i have read a bunch of different posts and no one explains. are you just pulling out all of the inside pipes and putting the ends back on?
  2. Titan800
    Titan800 New Member
    FL
    Yes, essentially. You cut before the welds, hammer, chisel, and pull the baffles out, well the caps back on. There is another process that IMO, is a lot easier, doesn't require welding and produces a much better sound than a fully gutted exhaust. The process that I used I found over at VFR Discussion.
    You can read the process here. I think you have to sign up to see pictures, which you'll need if you go that route.
    A New Way To Gut Your 6th Gen Exhaust - Exhaust Systems - VFR Discussion
    I wrote a post about my process and experience over there as well. Video included. It's like a brand new toy and the sound it produces is incredible. And it only cost me $26.
    Exhaust Notes and Black Shields OH MY! - Exhaust Systems - VFR Discussion
  3. junkins45
    Keyser, WV
    alright...thanks alot for your help. i thought about just doing the dremmel but i have a welding unit readily available so i figured i would just go thru and do the full gut just got confused with the part.
  4. Titan800
    Titan800 New Member
    FL
    Yeah both achieve the same results. I didn't have access to a welder and didn't want to deal with it. The Dremel method only took about 1.5hrs. If I had to do it again it would probably take 45 min.
