handle bar wieghts
Discussion in 'General VFR Discussions' started by Ravent25, Aug 16, 2012.
  1. Ravent25
    Ravent25 New Member
    Knoxvillem TN 37931
    Ok I need to find out how to get the bar weights out. i replaced the grips and want to replace the bar ends. I can see what looks like a pin or spot on the bars. how do I get these out. I tried to look on hear but I must not be putting in the right search info. thanks for any help..
  2. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    There's a little pointy thing on the weights that stick up into the small hole in the bar. Use a small screwdriver/awl or something to press down in the hole while pulling/twisting on the weights. Usually helps to spray some WD-40 into the hole first to kind of lube things up.
  3. Scubalong
    +1 FJ12ryder........:thumbsup:
  4. Scubalong
    +1 FK12ryder.........:thumbsup:
  5. Ravent25
    Ravent25 New Member
    Knoxvillem TN 37931
    thanks for the help..
  6. reg71
    Sikeston, MO
    Oh, I guess we shouldn't have drilled out those divets then. <blush>
