Hard starting next day after riding
Discussion in '3rd & 4th Generation 1990-1997' started by smcmillen66, May 5, 2020.
  1. smcmillen66
    smcmillen66 New Member
    Hey guys, I recently bought a Gen 3 with 26k miles from original owner that runs very well.
    It was due for plugs and other basic maintenance, which I performed.
    Once done with the maintenance, I filled the tank and have been riding daily.
    It's now been tough to start the day after a ride - this has happened 3 or 4 days in a row.
    Seems like it's not getting enough fuel.
    I have the choke full on. Manual says to not give it any throttle while cranking.
    Once it fires after about 5-6 tries, it runs great. Before the maintenance, it would fire on the first or second try with choke on.
    Any thoughts? The idle was set high - about 1300, so I dialed that back a bit to about 1000 as part of maintenance. Not sure if that might have something to do with it.
    Thanks!
  2. RllwJoe
    RllwJoe Member
    Idle should be at 1200 ish with a warm engine. That might help with the staring problem.
