Has my R/R been upgraded? (pics)
Discussion in '5th Generation 1998-2001' started by hank.sd, May 8, 2016.
  1. hank.sd
    hank.sd New Member
    South Dakota
    Clearly the R/R side connector is newer than the wiring harness side connector, judging by how white the plastic is.
    Also, the wires appear to be much heavier gauge on the R/R side. I don't see much for identifying marks on the R/R.
    I was happy to see no sign of burning / melting in the connectors...
    What say the experts?
  2. Y2Kviffer
    Y2Kviffer Insider
    RALEIGH, NC
    Definitely been replaced, likely a Ricks RR....
  3. hank.sd
    hank.sd New Member
    South Dakota
    Thanks for the response! For sure its been replaced, and I was hoping not by another OEM unit. I figured it was something better than OEM judging by wire size.
  4. Y2Kviffer
    Y2Kviffer Insider
    RALEIGH, NC
    Yep OEM woulda been the same small wires.
  5. Viffered
    Viffered New Member
    Houston TX
    Yes Looks like Definitely been changed since its upside down! Re-mount it right way and then you'll see its product numbers on the top!
  6. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    Solder those wires before you melt your RR or Stator. Those OEM connectors are pure shite.
    You will be able to tell what type (Shunt / MOSFET) of RR you have by the #'s on the heatsink.
  7. ridervfr
    FH is mosfet unit, robust upgrade to the stock crap, which starts with SH, 90% on this one.
  8. hank.sd
    hank.sd New Member
    South Dakota
    Ha! I thought the wires looked odd pointing up.
    These are the only numbers. 1010
    Sent from my TRS-80
