hate to ask (fairing clips)
Discussion in '3rd & 4th Generation 1990-1997' started by tomservo, Mar 15, 2009.
  1. tomservo
    tomservo New Member
    Davenport, IA
    So I went to change my spark plugs yesterday. I get to the part where I need to remove the plastic near the radiator. The book says push the middle of the clips in and they will come out. I can't do it. I appearantly don't understand this technological marvel. Any help? Thanks.
    -Eric-
  2. 34468 Randy
    If you look closely, you will see that the clips appear to have a centre button. Push on that, and the clip pops open comes loose and easily removed...or something like that.
  3. mello dude
    Romania
    I had a '95 4th gen and the the clips had a phillips screw head to undo them - is yours the same?
    MD
  4. tklm539
    tklm539 New Member
    I could not get the ones off my 99. Did not work like they should. Had to replace 4 of them at $2.50 per from the dealer. It was killing me for a little (but needed) piece of plastic.
    Dealer said he breaks them all the time on his own bike.. did not really make me feel any better. The new ones do work as they should (for now).
  5. Fizz
    Fizz New Member
    San Diego, CA
    My bike doesn't have a fairing but it does have those clips. I've always found that a bike key is usually a great tool to press the center button in, it's too wide to push them in all the way through but thin enough to push the center; I've got those type of clips for my chain guard.
  6. Slothrop
    Slothrop New Member
    northern lower Michigan
    On my '96, some of the clips are the push-button type and some have a phillips head to unscrew them.
