Hazard lights electrical gremlin
Discussion in '5th Generation 1998-2001' started by Markvfr800, May 20, 2014.
  1. Markvfr800
    Markvfr800 New Member
    Lads, need help with this---
    --- as I start to operate bike now the two indicator lights flash on like hazards non stop, the only way I can stop it is by disconnecting the battery.......... I recently went through most connections to check/clean coated with vasoline and retaped/secured, I also changed out the fuses as and where I found them------ the bike went around 60 miles after this work without any issues. Any ideas?
    -its a 98 FIw, has alarm fitted
  2. Terry Smith
    There should not be any power to the flasher unit with the ignition off so my guess would be your alarm unit, as that would be the only part that is permanently powered. Can you disconnect that from it's power supply?
  3. Markvfr800
    yes, seems to have solved itself with a bit of play from the on/off button department-- trying to wire in comms system soon so ill prob take another look at it then..........
