Headlight Dim with Turn Signal
Discussion in 'Mechanics Garage' started by Drakien, Oct 1, 2015.
  1. Drakien
    Drakien New Member
    I have 2007 VFR800, I noticed while sitting in traffic yesterday that when my turn signal is on the headlights dim ever so slightly, nothing major. The bike has a 1year old battery in it (whatever Honda sells). Is this a problem I need to be concerned about or just one of those minor things that bikes do?
  2. sunofwolf
    sunofwolf New Member
    sounds like a charging problem, my 06 does not do that
  3. Underoath87
    Underoath87 New Member
    Orlando, FL
    I haven't noticed that on my '07.
  4. squirrelman
    At idle speed while sitting in traffic it's probably normal. Battery isn't being charged at idle, so the extra signal load would lower system voltage.
  5. grabcon
    grabcon New Member
    Castle Rock, CO
    I would check the ground connections on the bike. The main frame ground, the negative on the battery and other ground connections throughout the wiring harness. Check their tightness and clean them up while you are there at the connection point.
