Headlights, dash don’t work?! Help.
Discussion in '6th Generation 2002-2013' started by OldSchoolInterceptor, Mar 17, 2020.
  1. OldSchoolInterceptor
    OldSchoolInterceptor New Member
    Spokane, WA
    I was changing out the rear brake lights and I heard a pop and now my dash, headlights hi and low don’t work. Blinkers and brake lights work. Clock works still and it runs fine. Any help guys?!
    check your fuses. was the key on while u were working ?
    OldSchoolInterceptor likes this.
  3. OldSchoolInterceptor
    Spokane, WA
    The owners Manuel doesn’t state which fuse is for what. Probably the one by the headlights? And yes i think the key was on. I’m an idiot...
  4. jstehman
    jstehman New Member
    Fuses are up in the cowl on both sides. I think there's 2 socket head screws holding the funny looking panels in
    Sent from my SM-N950U using Tapatalk
  5. OldSchoolInterceptor
    Spokane, WA
    Got it! 10amp fuse blew.
    jstehman likes this.
  6. OldSchoolInterceptor
    Spokane, WA
    That was an undertaking!!
    mines non ABS so it’s on the front brake side. The small panel felt glued in there. I thought for sure I’d break it but it eventually came off.
  7. jstehman
    jstehman New Member
    I know right?!
    I thought for sure I was gonna break mine
  8. OldSchoolInterceptor
    Spokane, WA
    This is what I ended up having to do to get them off. Crazy right!? I’m not sure what bolts should go back in the stock location. The ones on there were way too long. I’ll have to order stock bolts from Honda. I believe they’re engine mounting bolts? It’s going to be really close putting on the new fairings without the hole because the bolt still sticks out about flush with the fairing.
  9. NorcalBoy
    Yes, they are engine mount bolts. M10x65 on left, M10x47 on the right side. The M10x47 is a Honda special bolt.
  10. jstehman
    jstehman New Member
    Gotta love the Honda special bolts
  11. OldSchoolInterceptor
    Spokane, WA
    Thanks NorCal! Do you use a specific website you’ve had good luck with? Also according to the schematic it looks like I need #16 and #23 and I might need #6 as well? Does that look right?
  12. OldSchoolInterceptor
    Spokane, WA
    I meant #14 NOT 16. Actually is it #14 or #16 it’s hard to tell?
