The other day I replaced the stock 55-60 watt bulbs with 90-100 watt bulbs. I guessed and assumed that on high beam that both filiments would be lit but I guess thats not what honda had in mind when they decided to put the H7s on the bike for the high beams. It seams stupid to add bulbs above the H4s only to limit the dual filiment bulb to low beam only. I tryed to get the high beams on the H4s to light by wiring them to the power lead on the H7s, they worked for about 3 minutes until they blew the 20 amp headlight fuse. anyone have any ideas on how to do this without blowing fuses
One of the main reason's I got rid of my Ray Charles ST-4 was the projector beam only worked during the day. I am giddy over the 6th generation VFR's head lamps. What a wide beam and great nite distance. Are you sure you want a change? 8)
