Heavy Steering?
Discussion in '5th Generation 1998-2001' started by rmcdougal, Oct 7, 2012.
  1. rmcdougal
    rmcdougal New Member
    Fortuna CA
    Just picked up a 1999 on Friday. Today I put 200 miles on it and I noticed that it has heavy steering in comparison to my friends gen 4. Is this normal for the Gen 5? My buddy and I traded for a few miles and he thought my bike was hard to turn left. I had to hang off the bike to get it to hold a line through a corner. Wanting some feedback on this. (Recorded this today 10-28-2012) http://www.youtube.com/watch?v=FLdnW7oBfso&feature=player_embedded
  2. SouthTexasRich
    SouthTexasRich New Member
    San Antonio, TX
    Worn tires?
    My last set had the center worn down due to a long daily commute and a broke owner. It required lots of effort to get it to lean.
  3. rmcdougal
    Fortuna CA
    Front has about 50% and nicely rounded. Rear now has 230 miles on it. tire pressure was set at the beginning 32 front and 40 rear. Also if I try to ride without hands it goes ever so slightly to the right. Could my forks be twisted or bent?
  4. Apittslife
    Apittslife New Member
    Clarksville, Indiana
    slight run off to the right is normal do to crown of the road. I would check how easily the front end turns with the front end off the ground.
  5. OOTV
    OOTV Member
    The obvious stuff to check first would be air pressure in the tires, and the steering head. Is the steering head tightened too tight? are the bearings any good?. A few other things will affect the steering, tire profile, ride height/spring sag and rake and trail. Do you know if the PO did any suspension modifications to the bike? Did they perhaps lower the forks into the triple clamps? (i.e. less fork showing above triple clamp) Flip/change the rear suspension triangle? i.e. lowering the rear without changing the front to match.
    Rake and trail is one place that you can really change a bikes attitude without spending a dime. I would see if you can look up the specs on the ride height and verify that the bike is set at the stock settings. But first I would check the front end for any issues. Bent/crooked forks, steering head bearings, steering head tightness. One other thing to check, in regards to your pulling issue, is whether the front and rear tires are straight and aligned, not only withing the forks/swing arm but to one another as well. This can affect your bikes straight line tractability, but on a typical US road with a high center crown, it will pull to the right some.
  6. Durk
    Durk New Member
    Pittsburgh, PA
    You are slightly under inflated with the tires, manual wants F36/R42.
    When I bought my bike it had an old worn out front tire, and while it jerked to the right as soon as you took your hands off it still turned left without too much trouble. I agree with OOTVS you may want search for some issue that might be negatively affecting the steering.
  7. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    I normally run F40/R42 on the street. Bumping up the pressure on the front tire is easy so it's worth a shot. I don't think you will get a radical change with just 8psi though.
  8. reg71
    Sikeston, MO
    Last time I noted that on a friends bike, he changed the front tire and the problem disappeared. I run 35 front and 42 rear but if that didn't fix it I'd think about new tires. Did you mention how old the tires are? OOTVS has lots of good suggestions in there too. I also noted heavier steering on some Shinko tires compared to the Pirellis I'm running now.
  9. tinkerinWstuff
    I suspect suspension and go with OOTVS. I had a lot of trouble with my 3rd gen holding a line and couldn't keep up with anyone. I talked to some people I trusted and explained that I know I'm not a good rider but there's no way I was that bad either. They proceeded to give me a lesson in suspension and geometry. Making some changes front and rear brought me up to the middle of the pack.
    When I got my 5th gen, I didn't even bother with the stock suspension and made some changes from stock before I ever bothered riding it. There are a lot of places you can go to get suspension help if there isn't anything mechanically wrong with your bike - including Jamie who's already posted in this thread. Well worth the money. I suspect the rear of your bike is sitting too low. What's your weight and your buddies weight?
  10. squirrelman
    If some PO changed the headset bearings from balls to tapered rollers the steering would be a bit heavier than OEM. i agree with anyone who suggested trying higher tire pressure.
    Heavy steering ?? I used to ride a '92 ZX-7, and it had farily hard steering, but the trade-off was the most stable and unperturbable front end i ever experienced. Awsome ! No VFR is even close to that stability.
  11. Big_Jim59
    Big_Jim59 Member
    Dallas, TX
    When I took my VFR800 for its first test ride I noticed it felt the same way. It was a pig at low speed. Very heavy feeling. I took it back to the shop and checked the tire pressure and found about 26F/34R. I jacked it up to 34F/40R and it felt great.
  12. rmcdougal
    Fortuna CA
    Thanks for all the advice, guys. Here is a shot from our ride on Sunday.
  13. tinkerinWstuff
    nice picture
  14. rmcdougal
    Fortuna CA
    I loosened the triples and the axle, shook it around and my diving to the right is better. I also added air pressure and upped the rear compression. Headed in the right direction.
  15. rmcdougal
    Fortuna CA
    Sent from my SPH-D710 using Tapatalk 2
  16. EpiEric
    EpiEric New Member
    Netherlands
    Lingewaard, The Netherlands
    Check the steering headset bearings ! It's Obvious.....imho.....
  17. TOE CUTTER
    Did anyone suggest steering head bearings yet?
  18. ridervfr
    No - my GEN 3 flicks like a stilleto, but now I am lucky if I get a pinky toe down in turns :sad:
    Cheers :thumbsup:
    side bar, tyre pressure on all my stuff - 34 front / 36 rear
  19. rmcdougal
    Fortuna CA
