Help!!!1986 VFR750FG
Discussion in 'Mechanics Garage' started by GavinS, Sep 21, 2009.
  1. GavinS
    GavinS New Member
    Bristol
    Hello,got this bike a while back,I know it was running,but it has been standing in a yard for ayear or so.Decided to chop it down and rewire it due to knackered components,so did so as per a diagram found at tom yehya racing.No spark at all.Tried a second hand black box from a vfr400,no success.The wiring I'm sure is correct and makes sense,are there any other problems these bikes tend to suffer from?The pickups check out for continuity as do the coils.I'm a bit flummoxed.I'm thinking of trying to make a CDI from scratch to a diagram for an old H2 Kawasaki,found at Lakeside.com,has anyone else done this,or found any other (cheapish)solution,I ain't got much money,thanks. gavinsaunders3@yahoo.com
    probably missing an earth connection somewhere, Guvna.
    you checked or by-passed the "run-off" switch at right handgrip ??
  3. TOE CUTTER
    simple
    Go with Squirrel....don't over think it, it will be simple problem.
  4. GavinS
    GavinS New Member
    Bristol
    Ar
    Yeah i'll checkit all through agin,cheers,m'dear!
