HELP (AGAIN) ! - Stuck Drive Sprocket Nut
Discussion in '1st & 2nd Generation 1983-1989' started by straycat, Mar 14, 2024.
  1. straycat
    So the Bike is still fighting me. NEVER had a sprocket nut fight me like this and I've removed alot of them
    I cannot for the life of me get the drive sprocket nut off the counter shaft.
    What I ave done so far:
    Bike in gear (5th)
    Bent the locking washer tab back
    Locked the rear wheel with a 2x4 (snapped the 2x4), metal tire iron (bent the tire iron)
    Impact gun - didn't work
    24" breaker bar - won't budge it
    Im concerned that anything more forceful. (longer bar or larger metal wheel jammer) will shear transmission gears
    If I take the bike somewhere to heat the nut with oxygen/ Accet, im concerned ill melt the countershaft seal and im not splitting this engine
    Nut has that metal locking clip ring inside it, no idea if someone used lock-tite too
    I may be forced to hand saw the nut with a dremmel tool par away then hit it with a cold chisel to split it.
    Whatever you do, don't use a hammer!!
    100% sure they are lefty-loosy threads? Just gotta ask, we are talking about Suzuki here.
    Dremel and split.
    rc24dk likes this.
  3. sixdog
    +1 with Cap.....
  4. tsmitty
    tsmitty Member
    Ohio
    Can you give us a close up on the threads? like a top view?
    2nd thought cut the nut
  5. straycat
    Cheers chaps
    Regular threads, not left hand
    when you say " don't use a hammer", I assume you mean on a wrench when trying to break it free because it will fuck the trans gears. ?
    Because im assuming ill need a hammer to split the nut with the chisel as I don't want the Dremmel too far and hit the threads.
    That I'm being a smart ass... as usual.
    Split that fucker.
    straycat and rc24dk like this.
  7. jstehman
    jstehman New Member
    Split the nut or 4ft iron pipe on breaker.. stand on rear brake pedal, 2x4 the wheel Don't use the trans
    Sent from my SM-S911U using Tapatalk
    RogueRC24 likes this.
  8. RogueRC24
    Split the nut, split the nut, split the nut!! Agreed with JS, use rear brake instead if possible.
  10. rc24dk
    rc24dk New Member
    Denmark
    Get a Honda
    straycat likes this.
  11. jstehman
    jstehman New Member
    Use the rear brake also.
  12. straycat
    Its off... no thread damage to the shaft !
    tsmitty, rc24dk and jstehman like this.
  13. straycat
    this wasn't coming off using the rear brake, I tried it
  14. straycat
    I have many Honda's, variety is the spice of life
    rc24dk and Bazza like this.
  15. straycat
    rear brake wouldn't hold it, I cut it off
    Fixed that for ya...
  17. RogueRC24
    Nice, maybe the bike will behave for a minute. :)
  18. rc24dk
    rc24dk New Member
    Denmark
    You seem to have good access to good and proper tools :)
  19. straycat
    Im a tool junkie, I've got tools for problems I havent even encountered yet LOL
    my next purchase is going to be an induction heater for bolt removal
    Colddevil and rc24dk like this.
  20. sixdog
    Cat has tools that fix tools.....
    rc24dk likes this.
