help! bike wont start
Discussion in '1st & 2nd Generation 1983-1989' started by marcsvf500f, Mar 26, 2009.
  1. marcsvf500f
    marcsvf500f New Member
    i bought this bike and it worked and started but now its nots. is there any known problems like the diode near the battery. btw i have an 86 vf500f interceptor
  2. volks6000
    volks6000 New Member
    Jacksonville , Florida
    need more info one what you have tried , ie.....check fuel filter , battery is charged. can't help with just saying it won't start. there is a fuse right on top of the starter solenoid.
  3. marcsvf500f
    the battery is new and when i hit the start button it does even try to crank and i took the starter out and cleaned it and that works i put the starter back in and still dont work and i hooked jumper cables to the starter and the battery and it cranks
  4. Octanis
    Octanis New Member
    Edited off.
  5. Octanis
    Octanis New Member
    Connect the solenoid straight with jump cable.
  6. volks6000
    did you check the fuse on top of the starter solenoid, if that is good then you have a bad solenoid. you can go to the dealer or e-bay to get a new one.
  7. ianjoub
    ianjoub New Member
    Homosassa, FL
    a solenoid will be a lot cheaper at a lawnmower shop
    could be a clutch safety switch as well.... be sure the bike is in neutral when you try to start it
    when you depress the starter button, does the headlight shut off... could be a dirty/bad starter switch
    is the kill switch in the on position
    is the key on
  8. ianjoub
    ianjoub New Member
    Homosassa, FL
    jumping it with a screwdriver is easier
  9. marcsvf500f
    i took the switch off and cleaned them and when i hit the start button the head light dims
  10. Mario98
    Mario98 New Member
    Santa Fe, NM
    i have a 98 but... scope the main fuse, might be blowing. make sure you are getting power to the fuel pump.
    now it IS or IS NOT turning over?
    if its not turning you probly are not getting power to the starter.
    if it is turning, might be fuel related, i.e., fuel pump, main fuse, maybe even the infamous R/R reg. rectifier?
  11. marcsvf500f
    it is not cranking but i hook the jumper cables to the starter it self it cranks
  12. Mario98
    Mario98 New Member
    Santa Fe, NM
    trace the pos/neg from the bat to the starter and solenoid, also use a voltage testor to make sure you find where the power stops. you are sure the bat. is new? make sure that has enough cranking amps to turn her over. look for blown fuses while you trace the wires
  13. marcsvf500f
    yes i know its knew cause i bought it and had it running the i moved the choke to start it the one weekend and now nothing
  14. masonv45
    masonv45 New Member
    The headlight is supposed to dim. Does your solenoid make a click? Inspect it for corrosion - it's very common. Replace if corroded.
    Also jiggle the ignition key with the start button pressed - maybe it's in the ignition switch?
  15. gunnarf06
    gunnarf06 New Member
    Hafnarfjordur
    Batteri is maybe dead or starter motor taking to much amps
    Hey
    Check the batteri if that is okay then use amper meter to see how much he is taking he shouldn´t go over 25-30amps.It can also be when you try to start it shoots between the plus cable witch goes in the starter motor and the body.
    Best regards
    Gunnar
  16. Ghost
    Ghost New Member
    Kernersville, NC
    Bad Battery
  17. marcsvf500f
    sometimes it does and when i hit the start key the head light shuts off and i am not getting power to the clutch safety switch but then sometimes the soleniod clicks
  18. gunnarf06
    Hafnarfjordur
    Check the amps
    Hey
    Had this problem with my bike light dims with full charged batteri then after to or three tempts to start the batteri is flat but you can hear the solinoid.This is your starter motor taking to much amps clearing out the batteri your plus pole on your batteri should be warm and your starter motor also.You can not see anything that is wrong with your motor beacause it is short curcuit.Use a amper meter to see this.YOU HAVE MOST LIKELY FRIED STARTER MOTOR.Your coils inside the starter motor are probarly vanished now.
  19. squirrelman
    How could this NOT be a bad starter relay??
    IF she cranks with a screwdriver across the contacts it can't be anything else. Replace it.
  20. marcsvf500f
    thing is i hooked up jumper cables to the starter from the battery and its cranking but i hit the start button its not working
