Help... Clutch and Brake reservoir suggestions
Discussion in 'Mechanics Garage' started by detroitrockcity, Apr 17, 2024.
  1. detroitrockcity
    detroitrockcity New Member
    Phoenix, Arizona
    Greetings,
    I have a 2006 VFR800i, and an looking for advice on replacement, rebuild or other ideas for my handlebar reservoirs.
    The sight "glass" on mine are so bad I can't really see the fill level.
    What do you guys/gals recommend?
    Thanks iav,
    DRC
  2. Totaled TL
    Totaled TL New Member
    Louisville, KY
    Contact the guy at this site: --> https://v4dreams.com/products.html
    He states if you send him measurements of your site glasses he can accomodate you.
    I have no personal experience with him, just passing along info I've saved.
  3. detroitrockcity
    Phoenix, Arizona
    I have seen sites claiming the same thing. I appreciate the help, and will keep it in mind for sure.
  4. Grum
    Grum New Member
    Sight glasses are easily accessible, are you sure you just can't clean the glass from the inside?
    I'm always amazed at how often Brake and Clutch fluid replacement is neglected, even by workshops. Its probably the most important routine maintenance item to be done. Fluid replacemnt and flush/bleed every 2 years MAX.
  5. Thumbs
    Thumbs Member
    Bath(ish)
    I’ve got his sight glass replacements fitted to my’89
  6. detroitrockcity
    Phoenix, Arizona
    I'm pretty mechanically inclined, but a little cautious when it comes to brakes/clutch on a motorcycle. Probably should just go for it and start tearing in. So much to do. :)
