I had the clutch master fail on my 96 VFR and need help as far as if there is a new cylinder available or do I have to buy a Piston set. This id the first clutch master that has failed on any of my motorcycles. Thanks in advance for any advice Chris
Is slave leaking fluid ? if not, clutch line might need bleeding. if leaking buy and install a new seal kit wherever it's needed, either slave or mc.
