Help! I turn the key to on and nothing happens!
Discussion in 'Anything Goes' started by 1fastred1, Oct 3, 2008.
  1. 1fastred1
    1fastred1 New Member
    I recently went for a ride and stopped for gas. When I went to turn the bike back on nothing happened. I mean, really, nothing happened. No lights came on, no guages came up nothing. Even the clock which was on when the key switch was off did not register with the ignition on. I tried the following with no better results:
    1. Installed a new battery.
    2. Let the bike sit and tried turning it on again.
    3. I checked the main, in line fuse near the starter and it is fine.
    I did notice that there is a scorch mark on the starter magenetic casing
    where that cable connects on the rigth hand side. It still looks intact.
    Nothing seems to work. I finally had it towed home. iIjust need some advice on how to proceed next. What I am considering is replacing the:
    a. magnetic starter switch (Honda batter fiche 94-97, part 8
    and/or
    b. The Contact base or switch assembly
    Or should I just take it to the dealership and let them diagnose?
    I thank everyone at VFRworld in advance for any help/advice they can provide to get my ride back on the road.
    1FastRed1
    1.) Ground circuit fault
    2.) Ignition switch failure
    It doesn't cost a thing to check them out........
  3. steven113
    steven113 New Member
    Pensacola FL
    follow the terminals with a meter or test light and see where the power stops. My guess would be a bad ground or coroded main terminal.
  4. WhiteKnight
    WhiteKnight Well-Known Member
    London, Ky
    I am thinking switch failure (or maybe the run switch was off? Been there, done that, not realized it, felt like a dork), or some fault in the switch wiring.
  5. NorcalBoy
    When the run switch is off all of the lights still come on, but the starter motor won't crank.
