Help Identifying electrical connectors from air housing removal
Discussion in '5th Generation 1998-2001' started by goflynn, Dec 8, 2015.
  1. goflynn
    goflynn New Member
    I just replaced thermostat and hoses in my VFR and put the throttle body and Air Cleaner housing back together but I now have some connectors I don't recognize or remember undoing.
    In the picture I have a connector on the right , white arrow , that i think is the Map Sensor 3P connector, it also has the ignition coil connectors attached. ( page 5-53 of the service manual , Diagram 2) is this correct.
    in my picture, on the left , downward pointed arrow no fill color. its the same as the other 3p connector. I don't know what this identical connector is or where it plugs in . Can anyone tell me what that is and where it connects to on the bike? if they have a service manual reference that would be awesome.
    gearoid
  2. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    Can't help you, but here's a bump for your thread. Good luck getting it sorted.
  3. Corkey
    Corkey New Member
    Portland, OR
    It is hard to say where those connectors go. You took your bike apart further than I did (tank, coils, etc.) What year is your bike. I will check my service manual.
  4. goflynn
    goflynn New Member
    Mine is a 1999. 5th Gen. Corkey , I thought you had replaced the thermostat on yours which required you to take tank , air housing and throttle body out? It's a nightmare but i am doing it as part of a class. But now I am almost back together and have no Idea where this connector goes. I have a scan of the manual but cannot identify it.
  5. Corkey
    Corkey New Member
    Portland, OR
    I did replace all of the hoses and thermostat. It is possible to do the job without removing the tank, coils and/or disconnecting the throttle bodies, it is a little less work but requires a little more finesse.
    It appears to be the MAP Sensor 3P Connector (5-14 of the Service Manual) and Throttle Position Sensor 3P Connector (5-20 of the Service Manual). Or possibly the ECT Sensor 3P Connector (5-18 of the Service Manual).
