HELP! securing side plastic on 5TH gen
Discussion in 'Mechanics Garage' started by Boosh63, Jul 11, 2009.
  1. Boosh63
    Boosh63 Member
    Timmins, Ontario, Canada
    I recently purchased a 1998 VFR800FI and I can't secure the lower left side because the spot the left site stay bolts is broken off.
    Has anyone had this problem and rectified it?
    Thanks in advance!
  2. vfrcapn
    vfrcapn Member
    Grass Valley, CA
  3. Boosh63
    Boosh63 Member
    Perhaps I should have been more clear. The stay is fine and the side cowl is fine. It is where the stay bolts to the oil pan that is the problem that threaded aluminum tab has been sheered off.
  4. Boosh63
    Boosh63 Member
    ...where bolt #18 goes into.
  5. KC-10 FE
    KC-10 FE New Member
    New oil pan or heli-coil, your choice. The pan is going to be around $110. A heli-coil could be as low as $10.
    KC-10 FE out...
    :plane: :usa2:
  6. NorcalBoy
    The mounting tab cast as part of the oil pan has been sheared off, you can't heli coil what isn't there. You are going to be buying a new oil pan, make sure you buy the gasket and a new oil drain plug sealing washer at the same time. Total cost is going to be around $140.00 including shipping.
  7. Boosh63
    Boosh63 Member
    Thanks fellas...off to ebay I go!!!
