Help, snow in the pipes 6th gen
Discussion in 'General VFR Discussions' started by Molsan, Apr 22, 2008.
  1. Molsan
    Molsan New Member
    Red Deer Alberta
    Well was riding for couple weeks this year but just got a very bad snowstorm.
    the bike is parked outside, and due to the wind snow has blown into the exaust pipes.
    I tried digging as much out as i could but there is still a fair bit.
    my worry is that it may melt and re freeze in the pipe.
    or block the flow of air when i start it.
    what should i do? do i run it now? do i wait because the pipes drain, wait even longer and it evaporates?
    am i a worry wart?
  2. jasonsmith
    jasonsmith Member
    Vancouver, BC
    I can't imagine that the snow "packed" itself in there. It should just blow out when ya start it. Unless your cleaning attempts packed it in.
    Me personally, I would run it.
  3. hondawolf
    hondawolf New Member
    Livermore, Ca
    I agree. I would try starting the bike, if it does, let it run. Make sure you let it run for awhile, even giving it a few revs to push anything out. Let it idle for awhile too, letting the bike completely warm up and letting the pipes get hot, as to dry out any moisture in them from the snow. Then let the bike cool off, and re-cover completely.
  4. benjammer
    benjammer New Member
    Bentonville, AR
    I concur. Afterwards (after the pipes cool) I would spray some WD40 inside the exhaust to help dry out any moisture/keep moisture out.
  5. RVFR
    Fire that baby up! pronto!
  6. FrankoQ
    FrankoQ New Member
    Laurel, MD
    Let it burn that snow.
