Help trying to read this fault code.Thanks
Discussion in 'Mechanics Garage' started by gagoots007, Aug 9, 2015.
  1. gagoots007
    gagoots007 New Member
    upstate ny
    Good morning people,
    I have been getting a blinking on an of on the fault indicator light. Bike is running great just bought it about a month ago. It is a 2000 model.
    Anyway I used a jumper wire and pulled the code. This is were I am having my problem in reading the code.
    This is what I am seeing, a steady blink all the same never varying, no 1.3 then 0.5 all the same over and over. Now am I reading this according to the manual
    as continuing to light,? short circuit indicator wire, short circuit in service check indicator wire, or faulty ecm.?
    Or is this 1 blinks, loose or poor contacts on the manifold pressure sensor(map)Open or short circuit in map sensor wire, faulty map sensor.?
    Bike only has 10,500 miles on it. It has two brothers exhaust .
    I tried to explain this the best I could, Any help would be much appreciated, thanks in advance. Ron... PS I am loving this bike.
  2. skimad4x4
    France
    French Alps & London
    This video may help:
    https://www.youtube.com/watch?v=MpHK7gMx2WY
    If the bike runs then use the procedure to look for current codes.
    If you have done work to fix something you may need to clear any old codes, as it may be warning about something which has been fixed.
    Code 1 should mean faulty MAP sensor or wiring.
    SkiMad
