Help with fork assembly
Discussion in '1st & 2nd Generation 1983-1989' started by savedrider, Jan 27, 2008.
  1. savedrider
    savedrider New Member
    Southern California
    I've torn down the forks on my '87 VFR700 and am preparing to put everything back together. My only concern is the bushing that has an interferance fit and must be driven down into the slider when reassembling.
    Are there any good tools that can be made at home that will accomplish this task or do I need to buy the special driver tool? Thanks
    often the old oil seal can be used on top of the new one to aid in protecting new seal on installation.
    best tool is the proper-sized length of PVC plumbing pipe. use plenty of fork oil to lube upper bushing/seal area.
    seal, etc should be driven in square, not tilted. it's all good when you have room to install circlip.
  3. savedrider
    Southern California
    Thanks!
    I got this done today using a 1 1/2" diameter piece of PVC pipe. Worked like a charm and only cost ~$4.00.
    Tomorrow I will fill with new fluid and start to remount.
  4. koorbloh
    koorbloh New Member
    Lynnhood, WA
    did you use a short piece? or a looooong piece?
    the piece I used was about 3 feet long, and I was able to just tap the far end with a mallet to get the desired results!
    but a smaller piece could be used too.
    I hope you used a rubber mallet if you used a short piece so as not to mar up your sliders!
  5. savedrider
    Southern California
    About a 3 foot piece and a rubber mallet.
  6. koorbloh
    koorbloh New Member
    Lynnhood, WA
    I swear...
    best method evar
    a guy I know stopped by and saw me doing that and realized I was better than him....short pieces FTL!
