Help with gaskets
Discussion in 'Mechanics Garage' started by dxmen99, Apr 17, 2010.
  1. dxmen99
    dxmen99 New Member
    Maryland
    I have a 1985 honda magna vf500c v30 and i need a float bowl gasket. I'm having trouble finding one. Does anyone know where i can find one or would a gasket maker/sealant be better off?
  2. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    Go to your local auto parts store. Buy an O-ring the same dia size of the others. Make sure it's longer than what you need. Get some super glue. Cut o-ring and fit to length on the float bowl. Super glue the two ends together. Note: super glue was first made for rubber and once glued will not come apart. Put a dab of SG at each corner bend of the bowl while laying in the o-ring finishing with the two ends on a straight run area of the bowl. Cut ends to fit now and SG together. No the gas won't eat away the glued ends.
    OR go to Honda Yamaha Suzuki Kawasaki Sea-Doo Can-Am Ski-Doo Motorcycle Parts ATV parts Scooter Parts personal watercraft parts Accessories and buy a gasket set. There is E-Bay also, but most of those are o-rings bought from an auto parts store and not form fitted for the bowl like originals, just the right size to make all the bends without cutting.
  3. captb
    captb New Member
  4. mrich12000
    mrich12000 New Member
    Calgary, Alberta.Canada
    Go here they have your parts. I just checked. I use them when Honda orphaned our bikes,
    I have a VF1000, had all my parts for my carb. also get CRC carb cleans for the overhaul
    Cheers Mike..
    Old bike barn, Cirrus sonic in Kitchener Ontario, Carb medic.com
  5. mrich12000
    oops wrong post
