Help with headlight....please.
Discussion in 'Mechanics Garage' started by DR.85\\750f, Aug 22, 2025 at 2:30 PM.
  1. DR.85\\750f
    DR.85\\750f New Member
    Wednesday
    Hello fellow members, I'm having trouble with my headlight. It did work,. Fuse is good bulb looks good, power to fuse no power at lamp. Is there any other gizmos that would be causing it not to work. I've tested the clutch diode and CDI and start relay by swapping out. i also checked continuity to the wiring at the lamp and i got it from testing both side and switching contact at the battery\ground. Now in not sure that is correct so please tell me if that is wrong. i don't have an on\off for the light just hi\low but I'm sure you have the same.
    if there's anything besides the hand control that I'm missing could you steer me in the right direction.///////////////////////////////////////////Thanks Oh its an 85 vf750f. Canadian.
  2. DR.85\\750f
    Wednesday
    i should add everything else is working as it should.
  3. DR.85\\750f
    Wednesday
    well i jumped it,at least i got lows,for now
    Make sure your start button isn't sticking partially in. Those old style switches are notorious for it.
    There is a no-mans-land where the button is in far enough to kill the headlight but not far enough to engage the starter.
  5. DR.85\\750f
    Wednesday
    ya ive had to put my own switch in place of the stock handle bar one.
