Find the photo you want to delete, once you select it look for a small row of Icons blow the picture. They will be below the Red Bar labeled "Additional Info". Pick the second one from the right, it will be labeled edit photo if you mouse over it. When the edit screen comes up the last line has a box to check if you want to delete the photo. I go through occasionally and clean out old stuff that is just taking up room. Action
