Help !!!
Discussion in '6th Generation 2002-2013' started by Guest, Aug 25, 2004.
  1. Guest
    Guest Guest
    Need help!!!
    I was installing the Genmar risers, everything is fine, torqe checking the last pinch bolt and IT SNAPS!!!!
    The piece is left in the outer half of the clip on ring, where the thread is. Drilled it, inserted the screw extractor - the &*($$^# extractor snaps....
    Took the right clip on apart, removed all controls, tried to work it out - NO SUCH LUCK!
    Need a source to purchase the right clip-on if my local Honda dealer will not be able to extrac the bolt piece.
    Thanks!
