Hesitation and ping just off idle on full twist
Discussion in '5th Generation 1998-2001' started by jptechnical, Oct 12, 2007.
  1. jptechnical
    jptechnical New Member
    I am still getting used to my 99 vfr800fi and learning the quirks. I have a new little 'things' that are bugging me.
    I just noticed it today, I have 75mi on this tank (I have run 4 tanks of regular through it) and it runs great, but I noticed two things.
    1. first noticed a backfire on hard engine braking in first gear as I sloooowly rolled the throttle back on so I dont whip the chain (too lazy to clutch it, I know). It was repeatable one more time.
    2. second, noticed that if I crack the throttle hard at idle there is a momentary hesitation and a little ping like detonation. It is very short and doesn't seem to affect anything.
    Both things happened around 200degree on the engine temp. I was tooling around the country roads, gunning the engine and running through the first three gears enjoying the sound. The bike has 13.3k on the odo and other than a Rick's R/R (So far so good!) and an aftermarket fuel pressure reg (not verified yet, just what the PO said). I haven't looked at the air filter yet and don't know if there are any 02sensor mods on it, I am not even sure if my Gen5 has them.
    Anything to worry about? I need new tires, and I would like to ignore this for a while if it doesn't get worse or if anyone else has had that issue.
    Any viffers near Buckley WA? I would like to listen to yours, I am not sure if I should be able to hear or am hearing valves clicking. I am the type that cannot enjoy riding without ear plugs because I fixate on every little sound.:frusty:
  2. eddievalleytrailer
    eddievalleytrailer Member
    Jonesborough, TN
    Aftermarket or modified exhaust can cause the backfiring you describe. You also may have an exhaust valve leaking a little.
    The ping may be telling you the bike wants a little higher grade of gasoline.
  3. jptechnical
    Stock exhaust. I will try plus next tank.
    does my 99 have an 02 sensor, closed loop?
  4. John451
    John451 Member
    Does yours have the plastic Condom or thin mirror stems ?
    If its a '99 build then probably not, O2 Sensors and Cats were introduced on the MK2 update in 2000.
  5. ZonaMan
    ZonaMan New Member
    Tucson
    My 98 has a TBR full exhaust and it has some little hesitations here and there and usually after start up, but I am hoping that a PCIII will fix that when I can afford it. You just have to be a little more careful when working the throttle and use the clutch when you need it. Mine will pop a little when downshifting too, but no big backfires. I run 91 octane in my bike all the time as well.
  6. jpedrogb
    jpedrogb New Member
    Spain
    Barcelona
    Hesitation just off idle on full FAST twist
    Im an owner of a '99 VFR 800 FIx and I have the exact same problem described on the thread title. I have searched around the forum but haven't really found any problem solving replies, or closed threads. Please do link up if you do know of resolved threads!
    Anyway, a bit on my particular case:
    My bike hesitates and is slow to react/stutters on FAST throttle blips from idle or when downshifting and fast rev matching. (by fast I mean a little bit faster than you would normally open/blip throttle when rev-maching during downshifts) My mechanic said that all FI bikes will hesitate a little if you open gas REALLY quickly... this sounded like BS to me; if anything a few milliseconds lag should be normal but there should be no hesitation upon fast throttle openings, at least not to the degree I'm feeling.
    During idle, if you yank the throttle open from fully closed really quickly it will stutter badly and almost seem to stall and not rev up at all until 3-4 seconds later.
    - Stock exhaust
    - TFI (a simple PowerCommander that has 3 knobs for adjusting engine performance at low, med, high rpm's)
    - Resonnace box removed
    - New spark plugs
    - Air filter cleaned
    - Valves checked (or at least I think they did!!! Who can u trust these days??!?!?)
    - 50,000 km
    If you roll gas smoothly and blip slowly, no problems, bike isn't lacking power, or running rough... everything seems to be going well, no surges etc.
    I've read about possible things to do:
    - Throttle body sync (only VTEC???)
    - PAIR valve system cleaning?
    - Any other suggestions/solutions if anyone can relate???
    Thanks in advance guys!
    Vsssssss
  7. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    The little ping tells me your a tad lean on you fuel map in that rpm range. Popping thur pipes on decel is also a lean trait. Yes you could run a higher octane as a bandage. Find someone to check the fuel mapping. A/F ratio can be lean at idle of 15.5. and as rich as 13- 13.3 on top end. Depends on what your motor wants.
    That's where I would start. You need to know your A/F for a good running machine. Experimentation is the only way to feel it, unless you have a dyno.
  8. jpedrogb
    jpedrogb New Member
    Spain
    Barcelona
    any more suggestions?
  9. pap11y
    pap11y New Member
    Sydney
    Hi All,
    After getting my bike dyno'd it was stalling when cold. I found some articles on the "Cold weather idle" on this forum.
    I did a dodgy to get it running ok (as I could not adjust the cold weather idle).
    My bike was revving at about 2000 because of this.
    Ever since I did this the bike was coughing and spluttering when I gave it a good twist from idle. There was a hesitation.
    Finally I removed the airbox to get to this bastard adustment and it is now ok. Cold start is idling at around 1500rpm.
    Since I have made this adjustment the hesitation/spluttering has gone away. The bike is heaps smoother.
    I only mention this as I thought I might need the valves done which is labour intensive or costly if you get someone else to do it.
    http://vfrworld.com/forums/mechanics-garage/29099-cold-idle-adjustment-video-00-01-a.html
    BTW: This is a bugger of a job. I have found that if you remove the cones from inside the airbox you can move it up enought to get the vice grips on the shaft of the cold idle adjustment. Otherwise it just spins.
    Its made a massive difference. Bike is now awesome again :)
    Disclaimer: I have read somewhere that honda don't recommend you adjust this.
  10. Wheelz85
    Wheelz85 New Member
    I had a similar prob with mine about a month ago. Started very suddenly pulling out of a petrol station - gave it a handful and it just wasn't happy. I was scared I'd put in the wrong juice at first! I think I found out what the issue was though. Last week it made a horrific noise and when i got back home I found the downpipe had sheared off! If you've still got the stock downpipes on there I'd suggest looking to replace them. I've been looking around at a few forums and its pretty agreed that they only last 30-40k miles.
