Hi From Nj !! I Need Help
Discussion in 'Introductions' started by JAMIE, Mar 4, 2008.
  1. JAMIE
    JAMIE New Member
    BERGEN COUNTY NJ
    I Went To The Garage Sunday To Get Things Ready For The Spring And Check The Charge On My 97 Vfr . To My Shock And Horror The Site Glass On My Clutch Resevior Was Dead Empty ! And The Clutch Handle Was Limp As My Sex Life After 20 Years Of Marrage ! I Saw No Stain Under My Bike ? Could This Mean That Its The Slave Thats Bad ? Does It Need A Rebuild ? Can I Do This Myself (pretty Handy) . Ant Info Would Be Helpful ...thx Guys/girls ....jamie
  2. WhiteKnight
    WhiteKnight Well-Known Member
    London, Ky
    I am just guessing here, but if there is no stain, I would tend to think the resevior was empty or close to to whe oyu parked it. Again, just a guess. I would get some fresh fluid and bleed the system and look for leaks. You can also pull the slave and look for signs of a leak there, even though there is no sign of one on the ground. AFAIK, hydraulic fluid does not evaporate like other fluids. Someone else may jump in with a better idea than mine.
  3. drewl
    drewl Insider
    Virginia Beach, Va
    not to insinuate a low IQ, but my glass looks empty when on the side stand, I have to tilt it up to level before I see oil. Just a thought.
    OK, I'm th one with a low IQ, you said clutch, not oil. NEVERMIND
  4. JAMIE
    JAMIE New Member
    BERGEN COUNTY NJ
    Thanks Guys For The Quick Reply ...wk , The Fluid Was Full 3 Mounth Ago ? Im Gunna Try To Top Things Off Tonight ? Ill Let You Know
  5. derstuka
    San Diego, CA
    I would top it off, and pump the lever a few times hold it in and look for leaks. Maybe put some white cloth or papertowel under your bike so you have an easier time seeing the drips. I would not ride it until you figure this out though....could get you into a pickle. I normally love pickles, just not those kinda pickles...
  6. JAMIE
    JAMIE New Member
    BERGEN COUNTY NJ
    Okay , I Topped Off The Fluid And Opened The "nipple" On The Slave , Wasnt Getting And Pressure . Then I Removed The Slave From The Case And Pushed In The Slave Puck While The Nipple Was Open And Got Sume Bubbles , Cloed The Nipple And Got Pressure . Yeah ! This May Be A Really Dumb Question , When I Removed The Slave From The Case , It Was Dry , No Oil , ...is There Supposed To Be Any Fluilds In There ? The Engine Oil Showed Full ...
  7. WhiteKnight
    London, Ky
    The slave is, of course seperate from the cases. If I remember right, there should be no fluids between the slave and the cases. However, you may get a small amount of weepage from the pushrod area, nothing major though.
  8. JAMIE
    JAMIE New Member
    BERGEN COUNTY NJ
    Thx wk ...So in my haste after buttoning up my bike after my skilless surgery I forgot to install the 2 bolt that hold on the seat cowl . I was so happy to have made my bike run again with my own two hands that I ripped up and down the highway near me at 85/95 mph , when i returned to my garage i notice that my cowl was no longer on my bike ....oh poo
  9. WhiteKnight
    London, Ky
    Bummer about the seat cowl, but I think those may still be available for the 4th gen. Glad you got moving again. :thumb:
  10. squirrelman
    just add more Dot 4 .....slave seals shrank and leaked but will recover in warmer temps....
    Worst case would be a $20 seal rebuild kit, but this problem usually heals itself.
  11. JAMIE
    JAMIE New Member
    BERGEN COUNTY NJ
    Thx Guys ...
