High altitude problem
Discussion in 'Mechanics Garage' started by dwendel, Sep 25, 2006.
  1. dwendel
    dwendel New Member
    Just curious if anyone else has seen this issue. I've got an 03 VFR with about 3K miles on it. Recently I took a trip over some higher mountain passes (I'm in Colorado) - elevations varied between 10,000 and 12,000 feet. At some point on each of the three passes my viffer died on me (usually more than once per pass). Nothing dramatic - the engine just stopped. It's never done it before or after, only at high altitude. Does anyone have any thoughts on what might cause that? The only thing I noticed was that the idle was a few hundred RPM lower on the passes.
    something may be wrong with one of the many F.I. sensors....barometric perhaps.
    or maybe icing up of the throttle bodies???
  3. dsirl
    dsirl New Member
    Boulder, CO
    I live in Boulder. I fequently ride at these altitudes and have not had the problem you describe. Did it happen just when you were climbing?
  4. Action
    Action New Member
    Albuquerque
    I've been riding the mountains here in NM, 10K – 11.5K, and haven't had any problems. Did you notice anything different with the bike other than it dying?
