Honda Vf 500 84 fan issue
Discussion in '1st & 2nd Generation 1983-1989' started by ALANBBBK, Jan 9, 2013.
  1. ALANBBBK
    ALANBBBK New Member
    Huddersfield
    So Ive finally got her running right ish so I put her all back together. Then run her on high revs for a while to ensure the fan kicks in which it did(excellent) Howeve now the fan wont turn off its on constantly. Any ideas guys I tried it again a moment ago several hours after and still on.
    Replace the thermoswitch on the radiator.
  3. jeremyr62
    jeremyr62 New Member
    Ireland
    Limerick, Ireland
    Yeah the swiitch that fits into the rad is almost certainly sitcking in the closed position. Just disconnect the two wires going to the switch and the fan should stop. If you short the wires together the fan will start again. Those swtiches do seem to give trouble and I replaced mine after the fan failed to come on (I could hear the coolant boiling!). I got a new swtich from David Silver Spares in the UK.
  4. ALANBBBK
    ALANBBBK New Member
    Huddersfield
    Im a little embarassed now its so obvioud I even disconected the switch to stop the fan and it just didnt click. thanks for your replies my switch must have just gone as it was actually working about 2 weeks ago when i tested it.
    Al
